By: allysoo
high peformance air filter
I have just bought a torque universal air filter from Argos and this is not as universal as I had hoped!
I need a square to round mounting adapator and heat shield. Can anyone advise me please?
  1. RE: high peformance air filter
    I'm afraid these things can be a contradiction in terms. Far from Hi performance ( unless you cunningly force cold air directly into it) they are prone to sucking in superheated air from the manifold even with a baffle. A £30.00 K&N pad filter in the original airbox is best really. I took my cone filter off, flogged it, and refitted what God intended..car runs sweet as a nut again.
    Illegitimis non carborundum est.
    Furthermore:
    There is always 1 imbecile left you never bargained for.
    0-60...whenever SnailClock
    Posted: May 22 2011 By: SlushPuppy   Posts: 258
  2. RE: high peformance air filter
     I agree
    1997 MX-5 1.8 Is Chaste White
    Posted: May 24 2011 By: IANZ   Posts: 53
  3. RE: high peformance air filter
    Are K&N really best? I'm told that they let more air in but they also therefore let more dirt in, increasing engine wear. And the best thing is to get an original Mazda filter. Do K&N versions make any improvement to performance? ['95 1.8 NA]
    Cheers
    David
    1995 1.8 NA in BRG.
    Posted: May 29 2012 By: antelope   Posts: 1
  4. RE: high peformance air filter
    Hi...
    I had K&N on my Mk1 & 2.5 (the typhoon kit)....
    While it didn't make any noticable difference performance wise, think you would need a good quality exhaust too to see anything worthwhile.... They can also make the engine a bit lumpy in stop/start traffic due to the engine heat.
    But I just loved the 'induction roar'.....
    You'll either love it, or hate it!
    Garffey.
     Tha' can alus tell a Yorkshireman, but tha' can't tell him much.
    Also: never ask someone if they're from Yorkshire. If they're not, they'll be embarrassed. If they are, they'll already have told you.
    Metropolitan Grey 1.8 Ac SE Rc with compulsory 'Oakers' sticker.....Thats it!!!!.....Not even DSC to annoy me!
    Posted: May 30 2012 By: Garffey   Posts: 3124
  5. RE: high peformance air filter
    In my experience, aftermarket "performance" air filters are usually surrounded by a load of advertising hype. Years back, being an engineer, I spannered now and then for a mate who ran an Escort rally car where it was noticeable that most of the entrants used standard OE air fiters. They used to call K&N, "The instant rebore kit" back then because they let so much grit and other rubbish past the filter - and I've seen first hand the results of what that can that do. Maybe they've improved them these days but I'll still never use one based on the damage I've seen them cause. I've also been told over the years by reputable people who have access to flow bench and other test eqpt that most makes flow very little if any more air than the std OE filter.
    When I had my '95 1.8 Eunos I made a cold air intake as an experiment - using the standard OE filter. I fabricated a NACA duct in the n/s headlamp cover to get the cold air in and the difference was immediately noticeable - not earth shattering but the improvement was probably better than a K&N or whatever, and it was a lot cheaper - and safer for the engine. Getting denser, cold air in there will do more for performance than any fancy, expensive piece of rubbish ever could.   http://www.oldgitbiker.pwp.blueyonder.co.uk/MX-5%20page%202.htm
    Dewi
    http://www.dewisant-photography.net/index.htm
    Posted: Jun 05 2012 By: Dewi Sant   Posts: 24
