By: cbcymru
Gear Selection
Stopped at traffic lights, then couldn't get into first. Managed to drive home but gear selection difficult.
However this morning everything seems OK.
Anybody have a clue what's happening?
  1. RE: Gear Selection
    Check the clutch fliud maybe you are loosing it 1st place to look is the slave cylinder pull the rubber boot back and see if the fluid drips out if so you will need a new slave cylinder, 2nd could be the master cylinder put your hand up under the clutch pedal it may be wet /damp the fluid may be weeping out.
      Just thought it maybe the gear lever gaiters breaking up and jamming the gear lever may be worth a look
    Alan
    2010 1.8 Miyako in velocity red mica I'm lovin it. 宮古市.
    2003 2.5 sport splash green gone but not forgotton
    You have the right to remain silent. Anything you say will be misquoted, then used against you
    There are two kinds of pedestrians: the quick and the dead..
    Posted: May 19 2011 By: alanw   Posts: 430
  2. Gear Selection
     I would say 99.9% certain that the clutch hydraulic system is sucking in air, the reason the clutch worked next day is because the air "rose to the surface" back to the master cylinder if that makes sense.
    Cheers Ian
    1997 MX-5 1.8 Is Chaste White
    Posted: May 25 2011 By: IANZ   Posts: 53
  3. RE: Gear Selection
    I agree with the above!  Almost all, '.... I can't get it into gear' problems are due to the clutch draging (ie not disengaging completely when you push the pedal).
    I had a BSA 650 A10  which had a horrible draging clutch.... soon learnt to scoot it up to 1 mph then it dropped into first a treat!
    Johnnie
    Posted: May 26 2011 By: Johnnieboy   Posts: 18
  4. RE: Gear Selection
    It was a leaking slave cylinder. Local garage  fixed it for £109.92
    Posted: May 27 2011 By: cbcymru   Posts: 8
  5. RE: Gear Selection
    glad the issue was found and sorted, cb
    here's to more trouble-free miles Thumbs up
    "You shall rue this day. Well ... go on... start rueing!" ~ SG
    Wave to ALL other 5 owners!
    It's the MX5 law.
    ~profile pic pondering~
    Photobucket
    STORM 1.8 Racing Beat backbox, K&N Filter Panel & Eibached
    WiMmed on 15.04.11Drunk
    Posted: May 27 2011 By: VO5 Jo   Posts: 6280
